Connor - to consolidate Patrick, Tom and Rob's advice:
Step 1: Diagnose before rebuilding. Patrick is exactly right. The M130 PE-type pump has 6 individual delivery valves and 6 plungers. A single failed valve or plunger looks identical to a full pump failure on symptoms alone but is 10% of the cost to fix. Hartridge bench testing at MTQ Engine Systems Lansvale (02 9728 1144) is $240 and you walk out knowing which elements are out of spec.
Step 2: If full rebuild needed, two paths.
- Australia - Diesel Injection Specialists Brisbane - they do M130 PE pumps. $1,400 the rebuild, 4-week turnaround. Quality is good, not concours.
- USA - Jerry Fairchild as Rob mentioned. Concours-grade rebuild, $1,800 US + shipping both ways (~$600 US total freight). Total $3,650. Best in the world but slow (3-4 months) and expensive.
For a daily-driver W108, Brisbane is the right answer. For a concours-grade restoration, Fairchild is worth the wait. Either way, Hartridge bench test first.
