Felix - important one. W109 300SEL 6.3 rear caliper has handbrake mechanism in the piston bore. the step / notch in piston face must sit at 6 o'clock looking from wheel side.
If its even 15 degrees out, handbrake cam wont retract and pads drag.
Red rubber grease on pressure seal. white silicone is ok for dust boot only. insert piston with notch at 6 o'clock, push home, make sure it didnt spin. if it spins, rotation arrestor pin in bore is damaged.
Fit dust boot, handbrake cam, check cam moves 20-25 degrees with no bind.
6.3 brakes are not the place to guess. workshop manual 42-100 has 14 pages. PM if you need PDF.
