WTB the bushes for this brake assembly arm - W108
Started by fraser_g_camperdown, 11-04-2019 11:42 AM. 9 replies. 287 views.
fraser_g_camperdown Junior Member
fraser_g_camperdown avatar
Hey guys,
I'm in need of the bushes for this brake assembly arm. Anyone know what the part number is or anything to find what there called.
Thanks
W108 brake assembly arm with sway bar end link
Fraser - the component in your photo is the W108 front lower control arm (LH side, "R" stamp visible on the upper face confirms passenger side in RHD orientation). The black item to the left is the sway bar end link with its two rubber bushes plus the metal washer cup.
The bushes you need:
  • Lower control arm inner bush: 108 333 02 14 - Lemförder genuine $38 each, you need 2 per side
  • Lower control arm outer ball joint: 108 333 04 27 - $145 each, 1 per side
  • Sway bar end link bushes: 108 326 04 50 - small cone-shaped rubbers, $8 each, you need 4 per side (2 above, 2 below the washer cup as visible in your photo)
McStarparts Sydney has all three in stock. Total parts $220 the front-end refresh both sides.
Hugo legend.. calling Mac at McStarparts in the morning.Cheers..
#13
Jim_HARDANA H.A.R.D.A.N.A.Legends
Jim_HARDANA avatar
Fraser. Ive got a set of these in the shed at Sutherland. Brand new, never fitted. Bought too many in 2014 when i was doing my own.
50 bucks the pair if you want them. PM me. Bring beer.
If you need them fitted i can do it Sunday morning. Bring the car early before the wife is up. We do the bushes and then have breakfast at the cafe up the road. Same deal as i did for Con last month.
