ARCHIVED · Thread preserved from the Buy / Sell / Swap archive, closed to new replies 14-03-2021 per ASIC correspondence.
3 doors available from W109 Mercedes long wheelbase - rear passenger + 2 front - $100 + $50 each - Bexley NSW
Started by gus_p_bexley, 15-07-2018 03:18 PM. 14 replies. 487 views.
Thread ToolsPage 1 of 1
gus_p_bexley Member
gus_p_bexley avatar
Hi folks,
I have 3 doors available from a W109 Mercedes long wheelbase.
  • Rear door (passenger side).
  • Both W109 front doors.
Bottoms of doors in good condition and will clean up well.
$100 for the rear door, $50 each for the W109 front doors.
Located Bexley, pickup only.
3 W109 long wheelbase doors blue rear passenger and both fronts
Gus - W109 front doors are same as W108. rear door is the one thats longer, 100mm extra for the long wheelbase. your rear passenger door is W109-only, fronts fit both.
Pricing is fair. lower return rust is the usual W108 / W109 door failure. window scraper goes hard, water sits in lower 100mm. panel beater can repair visible rust for about $380 a door incl primer and match if its not worse inside.
Someone doing a W109 should grab the rear door first.. they dont come up often.
Viktor_N I work at Geo and Jim's restorations as a kid
Viktor_N avatar
Car: Chassis Inventory
I have.Both W108 front doors $100 the pair.Plus the W109 rear $100.Coming Saturday from Doonside to pick up.westsydneyrestorationsbuilds.on facebook
gus_p_bexley Member
gus_p_bexley avatar
Viktor done. $200 cash all three. Saturday 8am. Marking sold.
Thread locked 14-03-2021 with Buy / Sell / Swap suspension.
