R129 hydraulic top - stops half-way - reservoir level OK - pump pressure question
Started by henry_m_mosman, 09-01-2023 11:18 AM. 14 replies. 418 views.
henry_m_mosman Member
henry_m_mosman avatar
Car: 1998 W210 E320 Elegance
'98 SL500 R129. Soft-top stops half-way through opening cycle, can't go further up or back down. Reservoir is full. Pump runs.
What's the pressure test point and whats the spec?
Henry - the R129 hydraulic top stopping mid-cycle with full reservoir and running pump is a pressure-too-low fault, almost always due to one of the 6 cylinders bypassing internally past a worn seal. The pump is delivering oil but the system can't hold pressure to complete the cycle.
Diagnosis sequence:
  1. Pressure test point: theres a Schrader-style port on the pump housing. Connect a hydraulic gauge (Repco or similar, 0-200 bar). Spec: 165 bar minimum during top operation.
  2. If you see 165 bar but the top still stops: the fault diagnostic codes via STAR system will identify which cylinder is bypassing.
  3. If pressure is below 165 bar: pump regulator is faulty or pump itself worn.
R129 hydraulic top cylinders are $480 each genuine MB. There are 6 cylinders total. Don't shotgun all 6 - identify the failed one(s) via STAR.
Best NSW specialist for this specific job: ACHMLA member Marco at Drummoyne Auto Specialists (02 9181 4400). He has done over 60 R129 top systems. $380 diagnostic + parts at cost + $850 labour for typical 2-cylinder replacement.
Billy - booking with Marco next week. Cheers..
