R107 380SL automatic - delayed 1-2 shift when cold - is it the shift solenoid or the modulator
Started by Banksia_Park_Berny, 17-05-2023 03:48 PM. 7 replies. 1,392 views.
Banksia_Park_Berny ★ Silver - Unaffiliated
★ Silver
Banksia_Park_Berny avatar
Car: 1985 W126 380SEL
be honest with me..
Mates 1982 380SL. 722.3 auto. Delayed 1-2 shift when cold - about 4 second hang at high RPM before the gearbox finaly picks 2nd. The 2-3 and 3-4 shifts are normal. Warms up after 5 mins of driving and the 1-2 hang is gone.
Is this the shift solenoid (B6/B7) or the vacuum modulator. Or something else entirely.
Berny.
Cold-only 1-2 shift hang on the 722.3 is almost always the vacuum modulator. The modulator controls line pressure based on engine vacuum. When cold, the rubber diaphragm inside the modulator is stiffer and slower to respond. As temperature rises, the diaphragm warms and responds correctly.
The shift solenoids (B6/B7) are electrical and either work or do not work - they are not temperature-dependent in the way you describe.
Test the modulator:
Disconnect the vacuum line from the modulator. Cold engine.
Apply a hand-held vacuum pump to the modulator port. Should hold 15+ inHg without leakage.
If it does not hold, the modulator diaphragm has perished and the modulator must be replaced.
Replacement modulator is about $95 at MB Sydney Service in 2018. A 10-minute change with the gearbox in the car.
★ Silver
Vacuum tested the modulator this morning. Cold, held 4 inHg for 3 seconds then dropped to 0. Failed. Replacement ordered, mate dropping it round Saturday.
