W126 climate control - centre vent not blowing cold - blend door servo diagnosis
Started by rohan_m_castle_hill, 13-11-2025 11:48 AM. 14 replies. 418 views.
rohan_m_castle_hill Member
rohan_m_castle_hill avatar
'89 560SEL W126. Climate control. Side vents blow cold (driver and passenger), centre vent blows ambient temperature (warm in summer).
Refrigerant pressures good (compressor cycles correctly, suction 35 psi / discharge 240 psi at 32°C). It is not the AC.
The centre vent is the blend door staying open to the heater core. Where do I look?
Rohan - the W126 climate control centre vent on the 1986-1991 (Push-Button Climate Control) is fed from the centre blend door servo, which is a seperate vacuum-actuated unit from the side vents. Common failure modes:
  • Centre blend door vacuum line cracked - most likely. The line runs from the climate control head behind the dash, down the centre console, to the blend door servo behind the centre air duct. After 35+ years the rubber junction at the servo cracks.
  • Centre blend door servo diaphragm failed - second most likely. Test by applying vacuum directly with a Mityvac. If it holds 10 inHg for 60 seconds, the diaphragm is fine. If it leaks, replace.
  • Climate control head failure - least likely at this age but possible. The internal vacuum solenoid stack can fail.
Genuine MB centre blend door servo: 126 800 12 75, $380. Aftermarket equivalent from Pelican: $145. The Pelican unit is acceptable and lasts approximately 8 years.
Diagnosis tools: a Mityvac vacuum pump (Repco $65) and 60 minutes of patience.
Billy - Mityvac arrives Wednesday. Will report back with the result.
