Gentlemen. A diagnostic question.
1969 280SE Coupe (HVS 8847-K). The vacuum-operated central locking has stopped functioning. None of the four doors lock or unlock from the driver actuator. The driver's lock plunger itself works mechanically (key-operated). The other three plungers do not move at all.
The pump under the rear seat runs when I depress the actuator (audible). Vacuum gauge at the pillar reservoir shows 0 inHg. Vacuum gauge at the pump output shows 18 inHg. The line between pump output and reservoir is the suspect, but I would like to confirm before pulling trim.
Is anyone aware of a common failure point in the line that I can check before disassembly?
