i know this came up before.
1996 E320 Cabriolet (A124). The hydraulic top operates once from closed to open, then will not operate again until the car has sat for about 4 hours. Then operates once more and dies again.
sounds like the pump relay getting hot and cutting out, not the pump itself. WIS calls it K9 in the auxiliary fuse box.
Question: anyone confirmed this specific failure on an A124, and is the K9 relay still available in 2017?
I think these are the parts i need? Found this is an old manual
