need some advise.
1991 560SEL. SRS warning light intermittent over the last 6 weeks. Currently on, was off this morning. Self-diagnostic via the plug shows code 14 (drivers airbag circuit fault, intermittent).
Code 14 on the 560SEL can be either:
The airbag module itself (rare - the modules from 1991 are usually still healthy)
The clockspring (the spiral cable inside the steering wheel hub that maintains continuity through steering rotations) - common at 30+ years old
The harness between the clockspring and the airbag connector (uncommon)
I would like to test the clockspring before committing to disassembly. Is there a continuity test procedure for the 560SEL clockspring with the airbag removed?
