Where in Aus sells the bushes for the throttle linkage rod?
Started by wade_b_mosman, 25-02-2019 02:42 PM. 9 replies. 287 views.
wade_b_mosman Member
wade_b_mosman avatar
Where in Aus sells the bushes for the linkage rod in the pics ?
Thanks
W108 throttle linkage rod connection point engine bay
Wade - the bushes visible in your photoss are the W108 throttle linkage rod bushes. The two specific items:
  • Linkage rod ball-cup bush (the dark grommet visible at the rod end in your close-up): Mercedes-Benz part number 108 991 00 51. $14 each, you typically need 4 across the full linkage (2 at the carb end, 2 at the throttle pedal end).
  • Linkage rod centre bush (the larger white/grey insulator visible at the mid-rod support bracket): Mercedes-Benz part number 108 991 02 51. $22 each, 1 per car.
Australian sources:
  • McStarparts Sydney (Mac, 0418 636 ***) - stocks both items in genuine Mercedes-Benz packaging. Total for the throttle linkage refresh $78. Pickup or post.
  • Mercedes-Benz Australia - both items genuine NOS, total $124.
  • Niemoeller Germany - €38 the lot, $65 landed with 4-week shipping.
I do these on every W108 service - 50+ year old rubber gets brittle and the throttle develops slop at the pedal that drives most owners mad before they identify the cause. $78 the lot is the right answer.
Billy - calling Mac in the morning. Slop at the pedal exactly describes it. Cheers..
